soldering job ...
Pa PITT
Stephenville TEXAS
Man I cobbled up a solder job today ...I won't say this was on my jeep ...But I was afoot..men..The vehicle I was in wouldn't start ..So I got it back to the shop cut off the cable ...Cleaned it with soda ..dried it off ...I had a new cable for something else ..So I cut it off peeled it back worked the 2 together about 1 inch looked good ...Get my solder gun ..a good one ..just not today ...it won't heat up today ..I needed another pair of hands mostly..So I got my cutting torch lit it ...It was so hot what a job when I got done ...Finally i got about a foot of solder in it ...wrapped it with black tape ..It started up the rest of the day ...I cant get a cable for this thing it's been DIS. an cost $178.00 before it was dis.NLV.
...Do you suppose it'll hold ...
ElkhartBronco
Cedar Bluff
Well, the question stands...."Do you suppose it'll hold"
My question is...........If it's on a jeep, does it really matter?
:);D ;) :)
kbldawg
Marshall, AR
I assume your talking about the battery cable? If so, I'd feel safer with a mechanical joint/splice when connecting two cables together of that size.
If you were to get a short in the system the cables could heat up enough that joint would fall apart, especially if the solder is questionable already.
Pa PITT
Pa PITT
Stephenville TEXAS
I wondered if it could melt but I was thinking that will be the 1st place I go look for a problem ..It's on a 1998 Grand Cherokee 4.0 L ..I didn't think the fire,off the torch, would do any thing down the line on the Positive cable ..And the battery didn't blow up so I guess I'm good ..After thinking about it I believe I'll take it to work and let the kid ''skitterJoe'' solder it with his cig litter torch ..I had one of those in New Mexico box but it had leaked empty ..I hate to be afoot ..Wish my Bronco would finish..
blubuckaroo
Grease Monkey
Ridgefield WA
Cable splicing and termination is part of my job so I make most of my own battery cables. I use #4 conductor and ends which I crimp then solder on. I have gone to side post terminals and have found them available at a good supply store. Put on some shrink tube and they look pretty nice. That's the only way to get the perfect length.
