I’m having an issue with my aux tank sending unit reading the fuel level in the tank. I think there may be interference with the fill tube blocking the sending unit float. I’ve searched the forums and have not found anyone with a similar issue.
My problem: Aux tank instrument cluster gauge was reading 5/8 full when the tank was full. It would eventually drop to Empty as the fuel level would drop. I diagnosed a bad sending unit and replaced it with a new TBP sending unit (aux tank part number, not main, with slightly shorter tube after the bend). With the new sending unit in the tank, the level reads Empty regardless of fuel level.
I do not believe it is a gauge/voltage/wiring issue:
- All other instrument cluster gauges work
- Main tank reads Full to Empty fine
- Aux tank reads dead Empty when pigtail unplugged (same for main tank)
- Aux tank reads pegged Full when pigtail short circuited (same for main tank)
- Aux tank reads across the full range with a sending unit plugged into pigtail but out of the tank
I do not think it is a sending unit issue (but I first thought the original sending unit was bad as it would not read above 5/8 when full—hence why I pulled it):
- New (TBP) sending unit benched tested fine on ohms (7.5-76.5)
- New sending unit made Aux tank gauge read Empty to Full when plugged into pigtail but not placed in tank. (But new sending unit in the tank is currently stuck on Empty—my current problem.)
- Original sending unit benched tested almost good after being pulled out (14.5-77.7)
- Original sending unit made Aux tank gauge read Empty to 7/8 when plugged into pigtail but not placed in tank. (Makes sense as it reads max 7/8 full when manipulated out of the tank).
- With the new sending unit in the tank, the gauge moves from dead empty with no power to reading at the Empty mark when power is applied, so I know the sending unit is “working” as far as wiring.
When I looked into the tank, I was surprised to see how the fill tube and vent tube look to be in the sending unit’s way. Both are close to the centerline of the sending unit opening, and both the vent and fill tubes “drop” down into the tank more than I imagined (they terminate at the 1/2 full level. I tried to get a tape measure in to see how far the fill tube protruded into the tank. It’s on the float’s side (towards vehicle center) and what would likely hit the float. I think I hit the end of the fill tube with the tape measure at about 9”. The float is also about 9” from the face of the sending unit. I was disappointed but not surprised when my installed gauge did not read anything, even when the tank had 7.5 gallons in it. Good news is I have no leaks after replacing both aux and main sending units.
Before I pull the aux sending unit again and start bending things, breaking things, and irrecoverably breaking seals, I figured I better talk to people smarter than me on this. It is a poly tank, but I don’t know of what manufacturer or how old. It looks to be in fantastic shape if original, so I doubt it. Restoration was done 15 years ago, I’ve owned the Bronco for 5.
Pic of the vent and fill tubes is looking straight in through the sending unit hole.
