SOWEGA Early Bronco Fun Run Albany Ga. Sept. 9-10-11
Revelation
Revelation
Well from the post i just read I am going on 100% Cameraman mode, gonna get SOWEGA into the calender!
Foamy, add one to the list, one of the guys from work is going to come out with his Chebby.
Revelation
Revelation
I'll pick it up tomorrow and have it in shortly thereafter. I've got a feeling though, I might end up leaving it in 2wd just for the hell of it.
Your only supposed to pull that one on a Friday night when your out on a date ALONE with a Hottie..
lonesouth
I am resigned, there simply isn't enough time in the day(without the kid). Tonight I got the power steering hose sorted, the power steering reservoir relocated, PCV valve installed, t-stat installed, carb fixed, intake plugs done.
Still to do:
install exhaust doughnuts
sort out the radiator hoses(still)
plum all the vacuum hoses
crimp plug wires
replace carb studs
rewire for the 4g alternator
install fan and shroud
install distributor
Just not enough time, and I know when I rush that things go wrong. Still planning on going, but not bringing the bronco.
fordfan
Excuses, Excuses
Still to do:
crimp plug wires
replace carb studs
install distributor
AW Man! I know someone that is going to be there that could do all that in the PARKING LOT!!!!:mad::mad:
lonesouth
I'll leave the door unlocked if the bronco fairies want to finish it while I'm at work :)
I'm sure we will still have a blast riding with other people, plus it is a good opportunity to get to know other people
Revelation
Revelation
Put it on a trailer and with the 25 or so that will be here we can have that done in about 5 min. or so, Just a thought.
Justafordguy
I can help tonight also but it sounds like you need to take tomorrow off work, your sounding a little sick to me.;D
lonesouth
Adrienne said she can be done at 7:30. Hope that's not too late.
Justafordguy
What time do you get home from work? I'll come over and get started and you can help when you can.
lonesouth
Sounds good!
Anyone have an extra radiator cap?
Revelation
Revelation
Camera is charged, Looks like I am going to put my old 35's back on for the weekend, but I'm ready.
