BoltTurner
Newbie
- Aug 18, 2012
- 33
Hi,
About a month ago I bought a '71 thats is in phenomenal shape. PO is an RV mechanic (this may be relevant) and took great care of it. Engine runs strong and I did a compression test today just ot be sure - all good. Engine internals are all stock - 2bbl, cam, heads, block, etc.
I replaced the spark plugs today, just to start fresh. Here's where it gets interesting - went to Autozone, they gave me motorsport plugs per their system. Got home - clearly the wrong size, computer must be wrong - diamater was way too small to fit, could praticly just drop them into the head through the spark plug hole.
Took them back, brought an original plug to show the computer was wrong. They look up an autolite plug to compare - the diameter was correct, but the electrodes were significantlly set further in (barely above the plug threads) compared to the plugs that were in there. I guess you can say the old plugs were taller. Old plugs were autolight #45. I ended up just getting new plugs that were the same as the old ones because, well, it ran pretty good before and clearly their system cant be fully trusted.
Now, given the PO took imaculate care of this truck, did all the work himself, and is an RV mechanic, could he know something the store doesnt? Or should I have gone with the plugs the store listed as correct?
