speaker installation in roadster panels
amfw
Has anyone installed speakers in their roadster backing plate panels?
It feels like a pretty logical place to put a couple speakers if you are running the inserts all the time. If you have done this, I would love to see pics, or hear about your experience (how you went about it, problems you encountered, level of satisfaction with the end result)
NicksTrix
i've got a set of take outs that where that way. def want to put a foam backer behind the speaker to protect it, as it gets a lot of elements in there than you think. a marine rated speaker would be a good choice too.
amfw
amfw
I was thinking of building a small, irregular shaped box to go back there I haven't had a look at how much actual space there is in the insert.. But i definitely want to protect it, and I don't really like the sound of unenclosed drivers.
Im going away for the weekend, but hoping to get going on the stereo/tuffy install when I get back on tuesday. I have 5.25" drivers for the front, and the WH speaker pods on backorder (if anyone wants to sell me a pair...) and some 6.5" shallow mount that I think can be made to work in the roadster panels.
Eoth
Yup, I did it. Very happy how it came out. Basically speaking, I went for the largest 3 way marine speaker that would fit. Cut the hole and used some sound-deadening material on the inside. I know that there is a science for proper enclosures but it really sounds good to my ears. I would reccomend the speaker to anyone but I see that they are discontinued.
https://www.crutchfield.com/S-eRAvI0OS66O/p_107DXI690/Polk-Audio-DXi690.html
I don't have any pics of me installing it but here are how they look after 4 years of service. Sorry I see that the pics are rotated all over the place.
amfw
amfw
oh yeah! thats great! did you fit 6x9s in there? glad to hear the setup has worked out. Looking forward to getting going on mine
amfw
amfw
Yes 6X9 speakers. One cavoite is that I have the backing panels that Gas Pig makes. I see he is doing another batch...
https://classicbroncos.com/forums/showthread.php?t=308394
They are really nice quality and thicker than the standard ones that the inserts came with. I don't know if a thinner gauge metal would perform the same.
Ahhhh, I noticed in the photos that your backing plates were different than mine. Mine dont meet up nearly as nicely at the seams. But that nice seal on yours could contribute to better sound! Mine are currently painted to match my truck, so I'll likely stick with them, and try and just build a box to mount behind them. i'm better at building boxes than painting
Eoth
Well..... I installed mine a bit different than what you are supposed to do. You are suppose to install the panel inside the fiberglass insert but I didn't like the mating surface (wasn't perfectly flush and it made a bit of a sharp edge that I rubbed against getting in and out). So I realized that I could keep the metal on the outside and secure the fiberglass behind it. I like the rounder edge and for me it sealed better. (hope that makes sense)
sprdv1
REBEL
and be very very carefull :D
amfw
amfw
So I am working on these now, and they are almost done! Pics to follow later, but I am pleased with how they are turning out and will look forward to reinstalling. I am wondering how people with roadster inserts prep/protect the door frames before installation. My rig came up from Louisiana. I am fairly certain it was flooded at some point in its history. The roadster panels had about a solid inch of mud in them when I opened them up and pulled them off. Now that I am getting ready for re-install, I am wondering if there is any special attention they should be given before being closed up again.
sprdv1
REBEL
fixed the pics...
Nice.. good luck...
amfw
amfw
this is the mud I was talking about
amfw
amfw
Some pics of the box and the panels
amfw
amfw
Fab man.. :) my biggest issue is getting away from "work" to find time for that kind of stuff :(
yeah, that "work" business really gets in the way! I finally have a place where I can have a basement shop (woodshop) and a driveway. No garage, but it beats wrenching on the side of a hilly street! Having tools organized and set up to go saves me time, but its still a lot.
amfw
amfw
I got the stereo wired up yesterday..... It sounds AWESOME. I'm very very happy. I'm even considering canceling my order for the kick panel pods...
