So, I got a nick in one of my rear axle shafts on my '66. I can't find any definitive info or part number for this application. Took the shaft to napa and they couldn't help either. Does anyone know of the part number for a sleeve for this application? The micrometer reading I got on that surface was 1.366" and the speedi sleeve 99149 specs are:
The nick is too long to try and use the double seal trick etc...
Thank you,
David
Shaft diameter, minimum | 1.497 in |
Shaft diameter, maximum | 1.503 in |
Thank you,
David
