Speedometer driven gears?? where to buy
G
Guest
Guest
what is the correct driven gear to use for 3.50's and 33X12.50's??? thanks
It sounds like your speedomet isn't reading fast enough. To make it read faster you need less teeth on the driven gear. 16 tooth is the smallest they make. It is a standard part. Just pick one up at the local ford dealer. Last I checked, about $3 less then the speedo shop.<br><br>I was running a 16 tooth with 33s, but I had 4.10 gears. (stock was an 18 tooth with the 4.10s) I don't think it will work with 3.50s. You may need a custom speedometer transmission from a speedo shop.<br><br>To stir the pot a little more, I think that there were 2 different DRIVEN gears. A 7 tooth or an 8 tooth. This is not confirmed, but I though I say it someplace once. I have no idea what would be original on what. Any one with a LOT of transfer case experence want to try this one?
