From your pictures that is what you would see on a jeep, and also what youwould see on an atlas TC at least the ones ive seen , that speedo gear housing is offset. if not done correctly either no engagment or partial engagment or to tight {= rapid gear wear,},, ,,, So just curious at how u had it installed take a small pocket screw driver and insert the drive where the speedo cable would engage gear and see if it will spin freely,= no engagement .. it shouldnt turn, do the instructions give you any info on proper indexing??
