hollowch
Looks like one of the 6 spindle bolts was all jacked up and I had to strip the female threads on the steering knuckle to get it out. The stock size bolt just slides through it and will not grip when I try to tighten. I got the other 5 torqued down no problem but its just that one that won't go. Is it a really big deal? Would I be fine with just 5 or should I go find a size up bolt, drill that one spindle hole a little bigger, and tap the female fitting on the steering knuckle to fit it?
Unrelated Question: What type of grease goes on the axle splines??
