Spline drive lug nuts
67sport
Vancouver Island, Canada
I've recently ordered a set of tires and wheels online. The wheels came with spline drive, small diameter lug nuts, which until I opened the box I didn't even know were a thing.
They don't look like they belong anywhere near a truck wheel, but reading about them it seems they get used on aftermarket wheels quite a bit.
Anyone have experience with these things? My plan is to put them in my junk bin and buy some new normal ones when I have the tires mounted, unless there's a good reason not to.
Thanks.
jamesroney
Fremont, CA
Thanks.
All depends on what wheel you bought. The majority of newer wheels are a high strength cast aluminum, and require a thicker hub section. In order to use a lug nut on the thicker hub section, the hub is usually counter-bored deeper and smaller diameter than you are used to. So the recess that the lug nut sits in is smaller, and you can't get a normal lug nut socket on it. So they either use reduced diameter lug nuts, or a spline drive nut.
I opted to use the spline drive nuts that came with my wheels because my impact socket wouldn't fit in the hole.
67sport
67sport
They're just 17x10 steel Daytonas. Certainly nothing special. I gave up on a few nicer wheels after really long or undetermined lead times.
Yeller
Rogers County Oklahoma
I hate them. Just one more tool to have to have. I put 3/4 hex drive, bulge head lug nuts on everything. 1 socket fits every thing in the fleet except the dually, not much I can do about that
These are my choice
nvrstuk
PNW
Just an FYI that even "name brand" lug nuts can be crap and cause an all day problem.
I bought some name brand lug nuts for my 914 build years ago. Put anti-sieze on all the studs, like always and everything was good till about 2 yrs later and I slapped the impact on a lug nut and it just spun. Couldn't get the wheel off. Took about 4 hours with welding a nut on the back side in the 1/2" of space I had (lucky I had discs- drums and I would have had to cut the drum in half while the wheel was still on-THAT would have been fun. Anyway, the welder and some dinking around and I got it off. The lug nut was not cross threaded and anti-sieze was used.
I have since gone to a much more expensive name brand and continue to (for decades) put 3 full turns on by hand before I use an impact.
67sport
67sport
Thanks for the input guys. I can see using them where required, but given these are old style steel wheels, I think I'll pick up some old style lug nuts.
.94 OR
Willamette Valley, OR
I ordered a set of slots from WH and the splined nuts showed up with them. Not something I was used to and attempted to bolt them up. One had a stamping issue and the socket wouldn't fit. I contacted WH and they were backordered but I was on the list of many... I ground the deformed edges down and marked with red fingernail polish so I could find it again and ran it until the replacement showed up. Jury is still out for me.
