Splines, Splines, and Splines.
md_lucky_13
Idaho
Just a couple of really quick questions for everyone here. Hopefully there are a few ideas.
I was reading the new Petersons magazine, and it got the wheels turning. This is usually a bad thing, because the faster the wheels turn, the more money goes on the credit card.
Here are a few questions that hopefully some of you axle gurus can answer.
I have a 69 9" axle in the rear. I am almost certain this is the small bearing axle. Its stock 28 spline. It hasn't broken yet.. yet..
I am planning on upgrading to 35, but I also heard there are some new 41 spline 9" axles with the ARB. I am sure Detriot will follow suit in the near future. So here are my questions:
1: What exactly does it take to upgrade to a 35+ spline axle? Will I have to cut out the small bearing ends and weld on large bearing ends?
2: What about inside the carrier? Will I have to do any internal modifications? (beyond simple new locker, resetting backlash, etc.) I'm talking about grinding anything, replacing any bearings for larger sizes, etc.
3: I want to upgrade my RP anyway. What would I have to change there? Anything beyond what a simple ring and pinion change would do?
My second set of questions is about the Dana 44. From what I read in petersons, you would have to install Dana 60 knuckles on the end. Aside from doing that, I am considering simply upgrading the axles, and, more importantly, the U-joints.
1: Is the stock Dana 44 spline count 30?
2: What would be an advantage of going above 30 spline count inner on the Dana 44? I guess I need to re-word that: what is the point of upgrading your inner splines to something above 30 spline count if your outer splines will remain 16? Is it cost effective?
3: Anyone every break a CTM u-joint with sub 37" tall tires? How about an axle ear?
And the final question......
From everything I have heard/read, Superior axle is the only way to go. Anyone agree/disagree with that?
I appreciate all the help. Of course, like usual, this is only the thinking phase.. But its something to chalk up on my "yeah, I will upgrade that when those break" list.
powersfab
West Michigan
A The 69 will be 28 spl Small Bering
1 for a 35+ spline you will need a nodgler case with bigger carrier berings. I Think you will need to up grade to big bering ends. 66 & 77 Have big bering but 28 spline
2 the nogler case is ready
3 Ring And pinion and replacement kit Berings seals and shims
d44 is 30 spline. i dont know if you can go bigger. but f150 axles have a biger u joint, and can be cut down to fit Moser dose this.
Hope i helped
I got 31 spline moser axels and ARB on the way !
mxpaz
KC
I have a 69 9" axle in the rear. I am almost certain this is the small bearing axle. Its stock 28 spline. It hasn't broken yet.. yet.. .Yep probably small bearing.
I am planning on upgrading to 35, but I also heard there are some new 41 spline 9" axles with the ARB. I am sure Detriot will follow suit in the near future. So here are my questions:Damn, what size tires do you plan on running?
1: What exactly does it take to upgrade to a 35+ spline axle? Will I have to cut out the small bearing ends and weld on large bearing ends? If your set on running a 9 inch I think you should get a 77 axle, or get a full size axle and cut it down if you dont want to run full width. Currie sells a spool that will bolt into your 3rd member that has 35 spline.
2: What about inside the carrier? Will I have to do any internal modifications? (beyond simple new locker, resetting backlash, etc.) I'm talking about grinding anything, replacing any bearings for larger sizes, etc. Yep, all the above.
3: I want to upgrade my RP anyway. What would I have to change there? Anything beyond what a simple ring and pinion change would do? Easy change.
My second set of questions is about the Dana 44. From what I read in petersons, you would have to install Dana 60 knuckles on the end. Aside from doing that, I am considering simply upgrading the axles, and, more importantly, the U-joints. Why in the world would someone put 60 knuckles on a dana44. Dana 60 knuckles on a 9 inch would be better. Just stick a 60 under there and a 14 bolt in the rear.
1: Is the stock Dana 44 spline count 30?Yes
2: What would be an advantage of going above 30 spline count inner on the Dana 44? I guess I need to re-word that: what is the point of upgrading your inner splines to something above 30 spline count if your outer splines will remain 16? Is it cost effective? Huge waste of money. Get a 60
3: Anyone every break a CTM u-joint with sub 37" tall tires? How about an axle ear? I doubt anyones broken a ctm. I havent seen one broke yet. I dont count the pro rock crawlers who put it in front wheel only and beat the piss out of it either.
From everything I have heard/read, Superior axle is the only way to go. Anyone agree/disagree with that? I have heard that too. I have no proof to support that though.
I appreciate all the help. Of course, like usual, this is only the thinking phase.. But its something to chalk up on my "yeah, I will upgrade that when those break" list If your gonna play in the rocks and havent sunk lots of money in your dana 44 like I have, just skip the upgrade phase and get a 60 and a 14 bolt.
ballistic64
Piedmont , SD
The Dana 44 your refering to in Petersons is an extreme rocking crawling setup,where light weight and clearance issues are a premium and cash is not an issue.The inner "C"s for the Dana 60 are available from Crane and since most 44s have 2.75" or 3" axle tubes they can be welded on the 44 axle tube ends allowing Cranes Dana 60 outer knuckles to be installed on the 44.Considering the inner "C"s are about $245.00 apiece and the outers are $345.00 apiece you have about $1200.00 just in these pieces alone,not to mention fitting 60 axles and finding a locker that will accept the 60 axles in the "side gears".
When it would be all said and done you could have one hell of a 44 built or a very decent 60.
jeff68
Hattiesburg, MS.
Why does everybody say that the '68/'69 Broncos are small bearing, my '68 came with a 9" big bearing rear axle, at least that is what was in it anyway.
I think that the U15 Series were the long roof (wagon), and these were big bearing axles, also the HD packages (model U132/U142) came with big bearing axles I think.
Please correct me if I'm wrong because I don't want to mislead anyone, but I think you should verify which axle you have before you assume, and go out and order something wrong.
I didn't mean to hi-jack this thread and no flame entended, I just needed some comfirmation for myself.
Thanks,
Jeff
Have never heard of 41 spline, but have heard of 40 spline. Usually just spools for dragracing.
There is more to axle strength then spline count. Check out diameter. A 44 outer is only 16? spline, but the diameter is about the same as the inner. So basicly just as strong.
The stock 260 joints are way too weak. the larger 297 size is much stronger. Upgrade to CTM, OX, whoever comes out with one next and not have any problems. Only seen a couple of broken ears with intact U-joints. Broken U-joint takes out the ears when it breaks.
Only aftermarket axle I looked at carefully after it broke was a Moser. No fillet between the stub and the yoke. Formed a stress riser and broke right there.
I think you can only get away with a 31 spline axle (with a conversion bearing) in the small bearing housing.
33 spline and up carriers (except for a few speciality spools) require a carrier with oversized bearings. Either have to have a stock carrier bored out or get aftermarket. The carier has 2 different bearing sizes (different then the housing bearing sizes) and a couple more different aftermarket sizes as well. 2.89 and 3.06(I may be off by a few thousanths here) are stock and aftermarket starts at 3.250"
Big bearing housings were an option for most years. Part of the upgraded GVW package. Factory 6 leaf springs instead of the standard 5 leaf.
md_lucky_13
md_lucky_13
Idaho
Here is my next question then:
Would a 31 spline 9" with superior axles and a 30 spline Dana 44 with CTM 297 U-joints stand up to 37" krawlers, a 351w and a sometimes heavy foot.
I'm not suggesting that I constantly hammer down hard, but if it comes down to either slamming hard and making it or turning around, I will always pick to go forward.
I want something that will stand up and not break 9/10.
Now that I have another rig, I want to build the bronco a little more hardcore. I'm aiming for 37s, and I already run 35s without any breakage so far (this includes the tiny stock 260 joints) and I hit things hard, many many times. I have stock 28 spline rear axles with detroit locker, and would also run a detroit up front when I upgraded shafts and joints.
Basically, I'm waiting for the rear axle to let go, and then I will upgrade, and then I am planning on locking the front, waiting for a joint to go, and then upgrading it also. I just want to make sure a dana 44/9" combo can stand up to 37s, or if I should consider going 60s...
And, speaking of 60s, has anyone cut a 60 down to near bronco size, and ordered new shafts? How much $$?
Thanks for all the help so far!
mxpaz
KC
If you can wheel with 260 u-joints and not breeak you wont have any problems with 37 and CTMs.
ballistic64
Piedmont , SD
I sure hope it will,Im building a similar setup.D44 frt. with electrac,superior chrmo axles and CTMs.9" raer with superior chrmo axles and detroit locker.Im also running a modified 351W-NP435.If you go the route your talking about I dont think your weak area will be your diffs.Itll come in the form of a broke D20 output shaft or driveline-ujoint issue,maybe a stripped hub.I cant say for sure.It sounds like we are trying to accomplish similar goals.My diffs are done (for the 2nd time) after deciding to sh*tcan the traclocks and upgrade now rather than later.
After a lot of thought Im storing the D20 and going Atlas.I cant see putting the cash into a stonger output shaft and lower gears or some kind reduction box when itll damn near be the cost of an Atlas anyway.Just be sure to think about what you want to live with on & offroad before you start letting the C notes fly.With the Atlas or a reduction box of some kind you can still run 37s and get decent performance on & offroad you just have to think about it in a sense of "for every upgrade I make where am I transfering the weakest link" then address it,and sometimes like in the case of a reduction box or aftermarket transfercase,it aint cheap.
md_lucky_13
md_lucky_13
Idaho
That is exacty where I am heading down the road.
I want to upgrade the axles, keep the 35s until they are bald, then get 37s.
Then I want to go with a ZF-5speed and a NP205 case..
But, that is down the road. I tried the "fix it till its broke" game for too many years now, and I have finally learned to just save and save, then replace it when it breaks.
I've decided to do the front axle first though, and then the rear once it breaks. Hell, if it never breaks, I will never have to throw money at it, right? :cool: :cool: :cool: %)
roksmurf
Russellville Ark.
Bowser, you should be fine with 31 spline rear I would reccommend looking at strange eng. axles , I run these in these in the rear with a strange full spool, and d44 and Warn axles/ctm's in the front and 16x38.5 tsl's they have held up VERY well . mine is a dedicated trail rig and sees alot of rock crawling.. I also saw the petersons article, gets ya to thinking... I dont think I would replace a well built 9" with a 60 though..
md_lucky_13
md_lucky_13
Idaho
Your running a spool in the front with 38s and don't break?
Well hell, I'm not worried at all then.
