Spongy Brakes
David63
I just installed a new brake booster, master cylinder and prop valve. I bench bled the master cyclinder and bled all the brake lines until I saw new brake fluid at each wheel.
My brake pedal is much softer than it was before. I can stop the Bronco when I hit the brakes, but the pedal is almost to the floor. Anyone have any recommendations for how to firm the pedal up? Thanks
bronconut73
A low pedal is almost always an issue with the rear brakes.
I knew an old man that used to say, Good rear brakes give you a good "pedal", but good front brakes give you good "stopping".
Check those rear brakes for their condition, adjustment, and bleed.
broncnaz
Did you check the adjustment of the booster rod to the MC? If the rod is adjusted to short then the pedal will go farther to the floor before you get braking.
alexpilcik
Do some checks on your master cylinder. I have bought shotty m/c before especially if they are refurbished. Make sure that is not your issue if you cant find anything else. Its the last thing you want to think of, but once again I have had that issue before and sounds about the same. Just a thought.
David63
David63
I did not adjust the rod to the MC when I installed it. I will check that today. Thanks.
David63
David63
The booster rod adjustment correccted the problem. Thanks
