Spot welding!!
Coob
Houston, Tx
Anyone have any experience using a spot welder? I was looking at the handheld model that has the smaller tongs. Seems really efficeint.
Of course you would not be able to spot weld all locations. But would cover about 50% perhaps?
eds66bronco
Essex, Vermont
i just use my mig... drill hole in top metal clamp or press together, fill the hole, grind smooth and you're done. most spots on the bronco would be way to hard to clamp both sides.
Also spot welders prefer nice clean metal. All 4 sides (both sides of both layers) need to be clean. I just plug weld with my MIG. The back side of the bottom piece doesn't have to be cleaned.
Now if you are doing a 100 point concorse restoration, spot weld is the only authentic way to go.
Coob
Coob
Houston, Tx
Nope - not doing exact replica sort of restoration. In fact I was just going to try it on my trail rig. I got lots of body work to do and was thinking of trying it out.
I'm pretty good with my MIG but I was curious about trying other things. I found a single sided spot welder / stitch welder combo.
The nice thing about the spot welder is the low amperage regulater. Its sort of like a failsafe to prevent from burning through.
