Spot welds and template
Dannothedude
Looking for advice on doing the spot welds on 1968 bronco. Needing to cut the welds from radiator support. What size is best and also need a template for the bronco sport emblems and reflectors for driver and passenger side fenders. Thank you
Vincen
I prefer either 3/8” or 5/16” at the smallest.
ssray
South Central NE
Something like this??? This just for example...Rotabroach was the first I ever ran across, they are UK based and high priced. Many different makers out there. Note that some annular cutters have arbors that use drill bits as a pilot and not the spring loaded point as in the Harbor Freight.
HF spot weld cutter
jamesroney
Fremont, CA
I use the Blair spot weld cutter. Link below. It’s not cheap but works and lasts a surprisingly long time. Replacement cutter parts are available. Im on my second tool (not blades, the tool) after using it to drill 100s of spot welds. I consumed maybe 6 of the cutting blades during all that time.
https://www.amazon.com/dp/B0082LFO8C/?tag=classicbroncos-20
Keep in mind that Blair makes two different things with the same name that they call spot weld cutters.
The first is a cheap disaster, designed to break every 10th use, and has a double cutting surface, will bite your skin, and is just garbage.
The second is the one @jeffncs recommends, and it works.
