twisted77
I am looking for some GOOD!!! spot weld cutting bits. anyone know about a good company?
Bryce
Bryce
Yea those look nice. I also looked at the ones from napa. Seems like to me a standard tiny hole saw will do just as good. I think I might just try that.
Bryce
I did'nt have much luck with the spotweld cutter.(very slow)I went with the chisel and grind off as Allen said.Very smooth when finished.I would have said this to start,but you only asked about the bit.;D
Just to clarrify this a bit..... You should weaken the weld by grinding most of it out first. Then air hammer, then grind smooth. If you just use the air chisel without grinding you will possibly tear and rip the good metal. You want the matting surface as flat as possible and without grinding first it will need dollying back into shape.
