drill 1/8 hole in middle of spot weld then use spot weld cuter clean paint off with wire wheel see spot welds better still need chisel and hammer some times and cutting wheel they dont want let go if spot weld cutter not center right when go back with new weld it back like they had it no space just put alot of them jump around keep heat from one spot have wet rag to cool it off as you go good luck
