I'm afraid you will need a bigger air compressor even if you paint it in pieces. Spray guns use alot of air especially if you use the proper HVLP fittings on the hose ends. Many people think HVLP (high volume low pressure) guns use less air because the low pressure part of the name. That low pressure is measured at the cap with a special gauge which is about 10 psi. Conventional guns measure about 25-30 psi at the cap. If you paint it with low air pressure you will get alot of orange peel even with a good spray gun.
What color are you painting your Bronco? If you are painting it a high metallic or pearl I wouldn't paint it apart because of the likely possibility of a color match issue. Reason of a color match issue would be marginal air pressure and problems with the orientation coat (also called drop coat). Especially if you are a novice painter.
With a 33 gallon tank reserve I would at the very least buy, rent, borrow a 110V air compressor or even better buy a bigger one and wire it for a plug into it into the dryer circuit in the laundry room.
A decent gun for the money is a
Devilbis GTI . It's not a SATA but for the money it's a great beginner gun. There are cheaper guns out there but if you use a cheap gun it will not atomize the paint as well and you will have orange peel.
