Spring perch on rear axle
chris
No more Rock Crawler
I noticed I am starting to spit out the aluminum shims on the rear axle again and I want to replace them by cutting off the stock perch and welding on new antiwrap spring perches.
I can't find a replacement perch! I can find 2" and 2.5" perches but the rear springs are 2 1/4" wide. The axle is 3" wide. I'm afraid if I use a 2.5" perch the axle will not stay straight since the U bolts will not be snug against the sides of the springs?
Anyone know where I can get these? Should not be that hard.
broncnaz
I think the 2.5 would be fine if I remember right the ubolts dont touch the springs anyways. Not only that it's really the clamping force of the ubolt's that hold the springs on the perch not the spring touching the ubolt's.
TexasBronco
Waterford, MI
Blue Torch Fab makes a set similar to the ones shown in your picture. If you were to call them up I bet they could make one smaller since they are 3 pieces that are laser cut and then welded together. I mean its worth a shot to see if the top section could be made to 2 1/4" rather then 2 1/2"
70_Steve
Old Guy
What would be easier is to install a proper steel shim instead of the aluminum one. Take a look at my Tech article Pinion Angle, under the Bronco Tech on the left of the screen. I bought my steel shims from http://www.4crawler.com/4x4/ForSale/Shims.shtml . Very good quality, and they bolt to the springs.
buknbrco
Fairfield
I went to a steel fab place, had them torch a 3.125" hole in the center of a piece of 2.25" thick plate. I forget the dementions of it but I made it to have a built in lift block. Then I cut it in half drilled the hole for the leaf center pin and welded it up. I think they charged me $80, No problems since then a little pricey but bullet proof
SaddleUp
Vancouver, WA
I run 2" wide (If I recall correctly) perches which I bought from the local trailer supply. If I recall right the last set cost me $8. It could have been less but wasn't more. 2" still allow the u-bolts to come down straight and are within 1/8" of the edge of each side of the spring.
chris
chris
Thanks guys,
I just ordered a set of 2.5" wide units that are 8" long and should help some with anti wrap. I am going to see about getting the Wildhorses spring plates for the top but have a question in to them to see if the width will work.
chris
scottmcwms
Montgomery, TX
chris said:
Thanks guys,
chris
Where did you find the 8" long perches?
Gummi Bear
Mountain Off Road Engineering - MORE to the Jeep crowd sells those perches. They make good stuff.
Hogback
I may be wrong but I don't think they will do much help for axle wrap. But those are some stout perches and it looks like those guys will custom build also.
Gummi Bear
They'll help some.
You're right, they're not a magical cure-all, but they do work a bit in your favor.
