SS Brake Lines?
ryoungbronco
Belmar, NJ
I have some SS braided brake lines that have been sitting around in my garage for about 10 years. There is some signs of rust but nothing major. Can I use them or should I consider buying new ones? They are the extended lines that go from the frame to the axle.
71broncman
Maysville, Ky
New. It's cheap insurance for something as important as brakes and after 10 years they might be dried out/cracked inside. As always with an EB it's just mo' money.
Mark
KennyB
Simi Valley
... hehe... you've spent more than $80 on worse things..... (and how good is the Stainless if it's rusting?)
Apogee
Tangent, OR
Braided stainless brake lines are basically a Teflon tube surrounded by a stainless braid with some sort of crimped on end fittings. Teflon is one of the most inert substances on the planet, so it's not going to degrade just from sitting in a box for 10 years. The hoses you have are probably not DOT compliant if they are 10+ years old, however I've had similar hoses on my F150 from Superlift for close to 15 years without any issues. I would probably run them personally. Worst case scenario is one ruptures...that's why you have a tandem master cylinder, so the opposite axle will still function. Those hoses could very well outlast your rig.
There are various grades of stainless, so of which are more corrosion resistant that others. The end fittings tend to be zinc plated steel, so if anything is more prone to rusting, it's the fittings. If you get any grit from a sander/grinder/torch/etc in the stainless braid, that will look like corrosion even though it's not the braid itself.
Tobin
broncnaz
X2 I would run them. It would be different if they were sitting outside in the weather for 10 years. but inside with little more than humidy and temps I dont see any issues with that heck you figure many there are lots of vehicles with stock brake lhose that are well over 40 years old running around.
There were DOT approved hoses for EB's on the market over 10 years ago. I bought a set about 13-14 years ago and I'm sure they were out before that.
patrickmitton
kerby Or.
Hey I would use them even alittle rust on the outside is no big deal. Even if you were to lose them you still have options when it comes to stopping your car,..don't sweat the small stuff
