Braided stainless brake lines are basically a Teflon tube surrounded by a stainless braid with some sort of crimped on end fittings. Teflon is one of the most inert substances on the planet, so it's not going to degrade just from sitting in a box for 10 years. The hoses you have are probably not DOT compliant if they are 10+ years old, however I've had similar hoses on my F150 from Superlift for close to 15 years without any issues. I would probably run them personally. Worst case scenario is one ruptures...that's why you have a tandem master cylinder, so the opposite axle will still function. Those hoses could very well outlast your rig.
There are various grades of stainless, so of which are more corrosion resistant that others. The end fittings tend to be zinc plated steel, so if anything is more prone to rusting, it's the fittings. If you get any grit from a sander/grinder/torch/etc in the stainless braid, that will look like corrosion even though it's not the braid itself.
Tobin
