kiteoregon
- Nov 21, 2011
- 292
Ok, so i have a 351W flat tappet and a D.U.I dizzy on a brand new build.
1) Find TDC on the compression stroke
2) Move to 10* BTDC
3) Seat the Dizzy, indicate the direction of the rotor, mark on base
4) Install cap and align plug terminal with mark on the base, this will be #1
5) Firing order is 1,3,7,2,6,5,4,8 so after plug 1 just move around the cap in a CCW direction following the firing order
6) Start up the engine (assuming it's been oil primed already and fuel primed)
7) Assuming it's running, pick up to 2000 RPM for 20 minutes (break in)
8) Adjust timing to be 24* @3200 RPM
This is my first motor build so any advice is welcome. The last thing i want to do is to burn it up and start all over.
KO.
2) Move to 10* BTDC
KO.
