. I think I'll put anti seize on every other screw and check them after a few months. I'll happily share the results. I can say the stainless screws look a lot better.
As a previous poster noted, the compatibility problem is between stainless and adjacent aluminum, not anything steel.
Being in the marine equipment business, we deal (successfully) with that issue every day. There are several brands and types of thread lube that deal very effectively with the issue; all contain some zinc and most include teflon as well. TefGel is probably the most "famous" and the marine industry swears by it. Mercury Marine sells their produce in tubes as "Special Grease 101" or something like that...
I use a zinc-loaded anti-seize on all the bolts in a 5.0, for example, that go through or in to the aluminum intake and the timing cover.
The WORST thing you can do..and we see it all the time, unfortunately...is use the Permatex brand anti-seize sold in every autoparts store that has copper in it.
