When I did mine (all new SS lines, ends, junctions and fittings), I had a couple of places that seeped under pressure. Just a few drips every time I drove around. One that I remember was the junction over the diff. Another was into an adjustable proportioning valve I installed. In both cases, I loosened them a bit (not removed all the way, a few turns) and made super-sure the line going into the junction was as "straight in" as possible while tightening, even holding it straight in while I tightened. This to make sure the flare was as seated as uniform as possible inside the fitting. It has been fine for three years or so now. (Of course, you have to bleed again after you do this.)
I had some similar seepage installing new SS lines on another project (my 53 chevy) just past weekend, even though it was as straight-in as could be. So I just had to carefully tighten it a bit more--more than I really like to. I hate to over tighten brake lines because we all know how easy they are to strip when loosening, but it worked and hopefully I won't have to try and remove them in a long, long time.
