Standard or Reverse Rotation Fan 351C
GrillMaster
I have a 351C that spins clockwise if you look at it from the front of the motor. Do I need a standard or reverse rotation fixed fan?
Water pump spins the same direction as the crankshaft (all V-belt setup and serpentine with grooved water pump pulley) is standard rotation
Water pump spins opposite direction of crankshaft (most serpentine belts, water pump rides on backside of the belt) is reverse rotation.
