So, I am trying to start my new engine just mounted in the frame with the original wiring harness just laying loose but hooked up. Do not have the body on the frame, just engine and the rest of the running gear. It has duraspark ignition. I have the positive battery cable hooked to the starter solenoid and the negative cable hooked to a bell housing bolt. Cranks over fine with the key switch, have 9 volts to the plus side of the coil and have 12 plus volts going into the module but no spark at the plugs. I'm sure I'm missing having something grounded but not sure what? What needs to be grounded in the ignition that isn't grounded through the distributor?
