Started tearing down axles-pics
msuforeman
Well the transformation on the 74 has begun. I have disassembled both axles as of now and will be sandblasting them on Saturday. Within the next 3 months I will add the f/r arbs, 4.88's, front warn axles, yukon rear axles, ctms--I already have all this stuff sitting in my garage but I've decided it's a good to do front disk swap, Por-15 the frame, axles (maybe), and a 2" body lift and some kind of suspension lift. I did not realize how bad off my springs, shocks, coils and all the bushings really were.
http://www.superford.org/getfile.php?id=93250&toggle=fullsize&filename=Bronco Axle Stuff 001.jpg
http://www.superford.org/getfile.php?id=93251&toggle=fullsize&filename=Bronco Axle Stuff 032.jpg
http://www.superford.org/getfile.php?id=93253&toggle=fullsize&filename=Bronco Axle Stuff 034.jpg
http://www.superford.org/getfile.php?id=93254&toggle=fullsize&filename=Bronco Axle Stuff 038.jpg
http://www.superford.org/getfile.php?id=93255&toggle=fullsize&filename=Bronco Axle Stuff 041.jpg
Nice springs huh?
http://www.superford.org/getfile.php?id=93552&toggle=fullsize&filename=Bronco Axle Stuff 073.jpg
70bucks
Valley Center SOCAL
Are those Jackman aluminum wheels? I have only seen one other set of those. I don't know what there worth cash money, but they are an a+ in originality. Yah, Yah ALCOAS are shiny and cool, but everyones got e'm.:)
Madgyver
Bronco Madman
Looks like you need taller jack stands.....
I like how clean your work shop is....
M
msuforeman
No, they are some cheapo chrome steel wheels that the previous owner had on there. They will be making a exit along with the BFG's to make room for the beadlocks and 37" Boggers.
Brian
M
msuforeman
I wish you could see it now--pretty nasty. It will be due for a good scrubbing by Sunday.
Brian
huged29
Ft Collins, Colorado
While you are putting on all of the goodies I would suggest beefing up your cage quite a bit. If you are gonna be doing stuff that can break warns and ctms you are definetely gonna want better cage.
M
msuforeman
I will be ripping out that pos soon enough---I can only do what money allows at the time. I'll have to save up a little while for a custom cage--or I might just save up and buy a bender so I can do my own cage.
Brian
