cougarmandan
I have a question or two. I have a friend that has a 72 F-100 with a 302 and granny 4 speed. He replaced his starter and it worked fine. It had a slight grinding noise when it started, but its seamed ok for a couple of months. A couple days ago, he calls and is having trouble. The starter spins, but its not engaging. I assumed the bendix failed and we took the starter to Oreilys for a warranty replacement. They did their test and they say it tested fine. You can see where the flywheel ground some of the nose housing off plus you can see the bendix is also grinding against the flywheel. They sold him a shim and sent him one his way. The shim was too small and he messed with it and cussed at it. Finally he came by and showed me what he had. I have my 68 motor out and happened to have my starter laying nearby. We compared starters. The previous owner had replaced the starter on my rig before he sold it. He never could figure out why it wouldn't start. I took one look an the cables that had more insulation missing than it had left and suggested that. "I just push start it, its fine" he said. Anyways, after I bought it, I replaced the cables that after noon and had a fully functioning starter/Ignition switch. Anyways, back to the topic. As we are comparing, I realized my starter is doing the same thing. It hasn't been used as much so its not near as bad but I was curious what starter to use. I am going with an explorer motor and a stock 3 speed manual. The auto starters go deeper so I doubt an explorer starter is the answer. Is the shim really the answer? Its seams kind of odd that ford never used a shim. Is it a production issue with the aftermarket starters or more of a compatibility issue? Since, I am using an 87 Flywheel, will that year of starter work?
