- Apr 23, 2013
- 618
I have read the other posts but don't see anything like what I have going on. Was starting fine last week. When to start it tonight and it would crank over and even start when I sprayed in starter fluid yet wouldn't stay started, then the starter would keep cranking over even after key was turned off. Spoke to Yeller (out of pocket now) and I started with the solenoid, went and bought new one put it back on (post was too short, took off the inside nut and it fit) and cranked it up did the same thing? Tried to start but just cranked, even had a jump starter connected to battery just in case battery was not at full.
I have a mini starter connected the same way I have always had it and it always worked fine. I connected it back the same way I disconnected it so I know the wires are in the correct location. I made sure everything was tight. Could me taking off the nut on the solenoid to give my self more room be a problem of not connecting properly?
I saw the main wire from the mini starter 4g wire I believe had a couple of electrical tape wound around them peeled one off and there is bare wire under but since it was tape I figured it was fine and taped it back (burnt on the headed is was it looks like)
I might add a independence power stud next to it so I can put the nuts back on the solenoid
Thoughts
Thoughts
