Starting issue with Carb
Rangerbj
My 1969 Bronco with 302, 3 speed, manual choke, 4 barrel carb will not start after 2-3 days of setting. But if I pour a small amount of gas down the carb, it fires right up.
If I start it within 24 hours of the last run up, it starts fine. But if I let it set for a few days, it won't start due to lack of gas in carb.
So is it the carb or fuel pump or ??
Thanks for the help
R
Rangerbj
Also, once engine is warmed up, it idles just fine. Also, drives real nice without any issues.
thanks
pcf_mark
What area do you live in? Some states have a 10-20% ethanol. In PA where I live it is 10% all year round. Alcohol evaporates very quickly. A hot engine shut down also put s lot of heat into the float bowl and squirter and the fuel evaporates. Today's gasoline is a very different mix than it was 50 years ago. It is aromatic - it evaporates quickly.
To confirm this next time it has sat for a few days take the air cleaner off and look down to see if the squirters for the accelerator pump squirt fuel. If not then the fuel has evaporated.
You can add an electric pump that primes or just let it crank a little longer to re-fill the squirters and bowls.
jckkys
The important info is the 2-3 days of sitting. This combined with hot dry air virtually guarantees the float bowls will empty when you try to start it. 5-10 seconds of cranking will refill the float bowl. You can also start and run the engine a few seconds on the shut down days and the bowl will stay full. Carbs don't like sitting for extended periods. DDs that only sit over night don't have this problem except in really hot dry weather. Summers here in Tucson can get extreme, so I deal with dry float bowls often. I never pour fuel down the venturis it washes the oil off the cylinder walls resulting in premature wear.
bluehair
That’s what mine does if the choke plate doesn’t close all the way. Takes a bunch of gas into the intake to get a cold engine going.
And though I've never tried this, you could confirm what's going on (I agree with the others about evaporation though) by removing the air filter when you know it's going to sit for a few days and cover up the bowl vents with something. Depending on the carb, you could plug them with something, or cover them with something that will seal them off.
This would not completely stop fuel from going places outside the bowls, but it would slow down the evaporation equation by quite a bit I would think.
If after three or four days your engine fires right up (or the squirters squirt) you've pretty much narrowed it down.
But I think y'all are on to it already. (but testing can be fun and enlightening anyway).
R
Rangerbj
thanks guys.
I never thought that the gas would evaporate that fast!!
I've had other carb broncos and that never happened. I'd just give one quick pump of gas peddle and it would start. But not this bronco.
Thanks again. I will try plugging the vent hole
nvrstuk
PNW
This was a common thread back in the early internet days mainly because there was such a higher percentage of us running carbs. Almost as many repeat questions as there are now about what color should I paint my Bronco and what size tire can I install on a stock Bronco! lol
Some carb models are MUCH worse than others.
Sometimes it's caused by heat soak as the gas in the bowl actually "boils off" when you shut it down - partially evaporates due to high air/carb temp. You didn't mention if your rig starts up PERFECTLY after 2 minutes of being shut off but sometimes this is it. If it doesn't start up easily with symptoms of having the manual choke on even tho it's a 90 deg summer day this could be it.
It has nothing to do with ethanol. Everyone seems to want to blame everything on it. Maybe it evaporates in a scientific study a bit quicker than 1970 gas but this problem has been around WAY before ethanol showed up at the pumps and was occuring in areas where gas wasn't mixed with ethanol.
Other issue is evaporation. Check the acclerator pump like Mark said after 2 days by removing your air filter lid, and operate the throttle a few times to see if you can hear and see fuel being squirted out into the venturi's.
I remember I put an electric fuel pump in to "solve" this problem back in the '80's. Didn't have the issue with my different Q-jets in the '90's up to 2016 when I finally went SEFI.
I used that same electric pump with a "T" and a shut off valve to be used for filling gas cans around our acreage here back in the day. Beats needing to run into town for gas for the pump, lawn mower, etc,...
