Starting Issues
71HorseInLB
All, my 71 was having problems sputtering / slow response after it warms up. I had heard the ignition coil may be the problem. Anyway, I replaced the coil and in the meantime also replace the solenoid. Now it cranks but will not fire. This wasnt a problem before I replaced both of these. I have pictures attached, if anyone can confirm wiring is set up correctly. I did also note that I have 12volts going into the solenoid and about 10-11 going out when cranking, not sure if that would account for the lack of firing or could my problem now be something else.
https://www.flickr.com/photos/190765725@N03/51348916021/in/dateposted-public/
https://www.flickr.com/photos/190765725@N03/51349143813/in/dateposted-public/
jckkys
The obvious questions are. Is there a stream of fuel from the accelerator pump nozzles when the the throttle is moved? Is there a spark at the end of the plug or coil wires?
where did you hear this? It's not unheard of I suppose, but it's also a common mis-diagnosis of a poor running engine.
Coils can be tested. With the piss-poor quality of modern parts from just about every source (including coils, but not as often as other parts) you've just now added two completely new possible bad parts.
Why did you replace the starter relay/solenoid? It very likely has nothing to do with any of the symptoms you first listed. While again it's not impossible, it's just low on the list. Was there something else going on, perhaps with the way the starter was working, that made you decide to replace the relay?
The main reason I ask is back to the quality of modern parts. The worst offender across all categories is very likely the replacement Ford starter relays. In fact, it's so common to have defective ones right out of the box, it's practically a joke these days.
Basically then, keep your old one if you have not already thrown it away. It was working before, so it's at the very least a good working spare. But it might be a saving grace if your new one fails.
The first thing to do when this happens is to put the old parts back on. Your new coil could be defective. It could also be wired incorrectly. Can you trace and explain each of the wires? There are way more than normal, and any of them could be causing the trouble.
What kind of distributor are you using? Points or electronic? Is the coil an exact replacement for what was working previously? If you have an ohm-meter, test it out compared to what is expected of a stock coil (if stock is what you had previously?).
Your wiring is correct at the starter relay. Looks good and clean and relatively new battery cables. But they can get old under the skin, so to speak, so need to be checked now and then.
The 12v to the first terminal is correct. Should be exactly battery voltage so double check that as a slight drop on a battery cable could equal a much bigger drop when the starter is pulling power to crank.
And the 10-11v is probably normal. The less drop the better of course, but any time the starter is cranking it's pulling the battery down and dropping the rest of the electrical system proportionally. Is this original wiring other than the battery cables? Looks to have been messed with at least a bit judging by the non-factory crimp connectors on the coil.
A way to test if the starter relay/solenoid is dropping voltage through it would be to disconnect the starter end and have someone hold the key to START and measuring voltage at that point. If it remains 12v then the relay is not a problem.
Next time you replace battery cables, go with big ones so your voltage drop during starting is minimized. Yours look like 4ga already, and that's good (original was likely 6ga?), but if you have the chance to use 2ga don't pass it up because people think it's overkill. What's a couple of extra bucks to have extra capacity?
Another test of the relay is to disconnect the Brown wire on the small "I" terminal there on the right. If the engine now starts (you said it has spark though?) then the relay is defective and somehow grounding out that I terminal. The Brown wire is connected to the ignition coil's positive side, via the red 3-wire connector at the back of the engine. The Red w/green stripe wire from the key to the coil goes into that plug, where the Brown wire is spliced into it. Helps to add extra voltage and current carrying capacity to the coil for easier starts.
Yes and yes
So you have spark and fuel? Did you touch anything else when changing the coil and relay? If you really have both, and the quality of your spark is good, then obviously it should start.
Could it be flooded from all the cranking? Is your choke closed when cold?
And speaking of the choke, are those other pictures showing the carburetor and choke also part of some questions you had? Did they get answered previously?
Just in case they did not, here are some comments:
1. In the pic showing the front of the carb and that boss with the holes, that is where a "reverse heat shield" made of sheet metal was screwed to the carburetor. It was designed to keep cold air from the cooling fan from keeping the choke cool and closed for longer than needed. One hole is for an aligning pin, the other for the attaching screw.
Good to have, but won't keep the engine from running if it's missing. However, it could contribute to rough running if the choke stays closed too long.
2. The large threaded tube on the backside of the carb on the other hand, should be capped off because it's a minor vacuum leak. Again, not enough to keep the engine from running, but enough to make your idle not quite perfect.
It's normally supposed to have the hot-air choke-stove fitting attached to it. Runs between the exhaust manifold and the carb. Unless you have all the correct parts (if so you should re-install them) you can find a small brass or steel threaded closed cap to seal it off from the outside world.
jckkys
The photos of the relay and coil don't include the most important info ie what's stamped on the steel mount of the relay and printed on the side of the coil with the manufacturer and model. The new ChiCom crap is less likely to work than the old parts they replace.
71HorseInLB
I am always humbled by what I dont know but always grateful the responses i receive. So yesterday I swapped out the newly installed parts for the old ones to the same results and ultimately put the new ones back in by end of the day. Today, it started like a charm and kept running very smoothly. So as I had installed the new parts fairly loosely yesterday, i went through tightening and checking over everything today starting it up each time i did a major change. When i went to reinstall the rubber cap on the cable from distributor to coil, i notice the cable was partly sliced so when i put it back in i got the same results as i was getting yesterday. Ran to Orange Engine by us and installed a new $1 cable and low and behold started up immediately! So the cable was the issue....for now ;-). To answer your questions and more questions from me:
1.) I swapped out the solenoid because i have always had to crank it twice for it to fire and always suspected the solenoid as the issue
2.) I put in Duralast parts
3.) I dont expect this is original wiring but i do not have the full history
4.) Will do on the 2ga battery cables
5.) Paul, i did not fully follow the "reverse heat shield" comment. Do you have a pic or link outlining where that should be
6.) I had suspected a vacuum leak somewhere with the sputtering and so have all of those usual suspects checked out.
Again, thank you everyone for your help!
Good find. With these old things you always have to keep your eyes open for the least obvious things. Stuff you don't automatically look at unless you've been doing it too long like some of us!
Nothing to do with cranking it twice. If it cranks (starter turning) it's working.
Does not effect how long or how often you have to crank it to start. So definitely keep your old one as a spare since it was working.
Unless by that you mean that when you turn the key to START it does nothing sometimes? Then the second time it cranks the starter?
If it's cranking every time you ask it to, how long to you let it crank before stopping and trying again? If you're like most people used to modern starters or have heard the horror stories passed down from grandfathers of starters overheating because you crank to long, you probably are not giving it a chance to start.
You might get lucky and they work for a long time. But they actually do have a pretty rotten reputation right now. Especially Ford starter relays and switches.
But don't give up. As long as they work it does not matter who's name is on them or where they were made.
A few pictures of the under-hood and under-dash areas and we might be able to tell you a little more about it.
Good. They should serve you well.
I think there was a discussion recently and I'll look for pics. But I just made that name up on the spot yesterday because it is in fact a "shield" but instead of being a heat shield it's actually trying to keep cooling air from the fan from keeping the choke's bi-metal thermal acting coil from doing it's job.
It's basically just a flat plate to block too much air.
jckkys
Duralast just means AutoZone. I hope you're not confusing them with Motorcraft Duraspark.
