Steering box lower seal replacement
BroncoKelley
Billings, Montana
Has anyone replaced the lower seal on the steering box? The one behind the pitman arm? How involved is it?
I need to put a new drag link on and that seal is leaking, so now is the time. Any help would be appreciated!
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Take the pitman off, remove the snap ring holding the seal in. Put a bucket under the box, start the engine, turn the steering wheel. The pressure from the pump will blow the old seal out (and make a mess without the bucket). Turn off the Bronco, replace the seal, snap ring, and pitman. Done.
hucklburry rev2
I wouldn't say so much words of wisdom as "man of little patience":D
Viperwolf1
electron whisperer
That method does work. Just be aware that there are 2 seals and 2 spacers that will come out. Single lip seal goes in first, then spacer, then double lip seal and other spacer.
Viperwolf1
electron whisperer
A turn to the right against the stops puts the most internal pressure on those seals.
