Ok in removing my steering column, I had all the bolts off but one. One of the two bolts located just inside the dash panel would just spin with the nut attached. The other bolt came out easily.
As you can see in photo below, the hole where this spinning bolt and nut came out of looks to be larger than the other.
Was this from the factory? Previous owner? or I just ripped the weld nut out?
https://drive.google.com/file/d/1Jv4y9zWlAQwpZsZz1CpPbsD4pXipzvAE/view?usp=sharing
Here is the bolt and nut pics:
https://drive.google.com/file/d/1b8OSpz2d_ChXGinyZeWYdhbEYhjBW0s6/view?usp=sharing
https://drive.google.com/file/d/1JDV3CZ1yLLYAgb1T2Hv_D45wuNi_-z8i/view?usp=sharing
This is a tight spot, I cant see how I could weld another nut without taking the dash apart. thoughts?
Thank you
Thank you
