Hello everyone,
I'm in the process of rebuilding the steering column of my 1966 (new bearings, chopping the full-length shaft to adapt to WH lower collapsible shaft, new wiring, new smooth collar, painting, etc.) which was previously converted from column shift to floor shift. As I start reassembling the steering column, I have a couple of questions:
- Is it necessary to reinstall the old shift tube, or can it be safely omitted now that the manual shift on the column is no longer in use?
- Also, I'm looking for recommendations on how to effectively cover the section that will be open towards the lower end, where the shifter arm linkages used to be. (aside from black duct tape)
