Steering Column Shaft Movement
danishbronco
Hi Guys! First post here, Im trying to restore a 67 Bronco in Southern Spain and Ive come across an issue that I cant find anything on the internet about and was hoping you guys might know. The inner shaft of the steering column comes out about half an inch when I pull on the steering wheel, Ive heard theres a bolt somewhere to tighten to stop it having this play, any idea where it might be?
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
At the bottom of steering column is a clamp around the steering shaft.
Un-bolt clamp, push in on steering wheel, slide clamp up steering shaft, and tighten bolt.
