DC_Gearhead
- Dec 28, 2015
- 660
I need a little help. I know I am missing some stuff on my steering shaft, and not sure what it is. My Bronco is not really “original” so a lot of parts seem to be missing along the way. Steering shaft is a good example. I took my shaft apart to clean up the bearings and starting adding a little logic. That’s where i went wrong I guess.
So at the bottom of the column the shaft has a plastic bearing race that slides up in the bearing of the column. There is a little washer with felt on it and a clamp that I installed.
I have an aftermarket wheel so it has what looks like a Grant kit. I have a metal bearing race that slides down in my bearing. The splined adapter slides onto the shaft, i put the black sheet metal cover over it, put the wheel on and i install the big nut. I read about a spring that gets installed to keep the pressure on the bottom bearing. Is that correct? The way I have it now doesn’t seem right and I’d appreciate any advice or pics.
Also, how it he heck do i get a horn on the wheel? The contacts work, but I have a push button on the dash for a horn.
Sent from my iPad using Tapatalk
