Steering Stabilizer bracket too small
Tulsa76bronco
I have a steering stabilizer that we just pulled off to put on the new BC Broncos tie rod kit which has a larger diameter. Now my stabilizer bracket won't fit over the tie rod. Where can I get a bracket that will fit this diameter. I talked to Jason at BC but he said he doesn't put the stabilizers on that much or that some stabilizers come with one. I don't want to buy a new stabilizer since my works fine
thoughts or suggestions
thanks
Shimmy
1977 Bronco
Maple Valley
i went from stabilizer to without one once i did my TRO and corrected my steering angles. i see no need for one now. any reason you feel you need it?
Tulsa76bronco
Tulsa76bronco
Thanks Yeller I didn't want to bug you, wanted to see if I could find one first. Shimmy not sure I do but since it was there and my other EB has one also with the new steering link I just figured I would put it back on....can't hurt
Yeller
Rogers County Oklahoma
If you’ll get me the OD of the bar and a pic of the end of the stablizer, I’ll whip something up.
Stabilizers are important, they help reduce steering box wear, protect the frame and bolts from fatigue. The ultimate in stabilizers is an assist ram, they are for more than just increasing steering power.
