I recently put new tires/wheels and noticed my steering wheel move right to left when I hit 50 mph for a little bit then is very smooth.
I’ve already changed the pitman arm which fixed the extra play in the steering wheel. I have balanced the wheels/tires twice. Most recently did a road force balance with the Hunter System and had an alignment as well. The shaking is still there! The weights are placed in the far outer part of the wheel. The tire shop said I’d they split the weights outer and inner it was going to require more weights. The tires I put on are the Nitto Ridge Grapplers. The wheels are Weld Cheyenne’s. Any help or ideas on where to look next would be appreciated. Thanks.
