edmedlin
My 302 has began running a bit on the rough side. It is basically a stock motor with a Edelbrock Torquer2 intake with EB 750cfm carb very mild cam. It doesn't use any oil, has great oil pressure and compression (110/ +-2 across all cyls ) It started acting like it was going flat when hitting passing gear then clearing up and running normal. It doesn't miss. It just feels flat. Like it is loaded up. Now it is like that all the time. It runs like it is at about 85% power. It starts good and all. I am going to do a tune up (plugs, rotor, cap and new fuel filter) and see if that might be an issue. Anyone have some other ideas???? Like I said, it all began only when I hit passing gear.
