Stock kickdown spring
turbotim2
____________
Would someone mind posting a pic of the stock automatic transmission kickdown rod attached to the carb and how the spring (assuming there is one) is attached? Thanks!
jckkys
Some both Holley and Ford carburetors had simple spring brackets others had holes in dash pot brackets or idle stop solenoid brackets. It would depend on what you want or what was OE on a particular year.
T
turbotim2
____________
Well I did mention stock - so 302, C4, 2100, stock kickdown rod.
1971BroncoSport
Hope these help.
T
turbotim2
____________
Perfect! So you do not have a seperate spring on the kickdown lever - just the one on the throttle return. Thanks!
jckkys
The kick down lever did have a return spring. You may get by without it because spring inside the transmission is usually strong enough to lift the rod, but Ford always had a return spring on Broncos with C4s. Again the front end was attached to different brackets and on Broncos there were always anti-dieseling solenoid brackets for this. Most owners removed them because they clutter the engine compartment.
1971BroncoSport
The ones above are from one of my 73's. This is from my C4 converted 71.
