Stock main tank sender
mini73
Got my main fuel tank cleaned out and just waiting on the filler hose and vacuum hose to come today so I can put it back up in the bronco. I got a new stock tank fuel sender and I was wondering if it were possible to put it in upside done? If I am not mistaking the electric plug connection goes on the top and the fuel line goes out to the drivers side right? Is there away that I can check the function of the sender, gauge and the position of it before I button it up and put it up in the bronco? I was thinking of just plugging in the electric plug and turning the key and holding the float in the full position to check the function. Would this work?
Viperwolf1
electron whisperer
Yes, and I recommend doing that.
mini73
mini73
Thanks viper. I just put the sending unit in the tank and put the sending unit lock ring on. Plug it in, turn the key on and nothing. I even tried flipping the tank over so that I could simulate full and still nothing. Switch the gauge selector switch also over to main. Maybe I don't have a good enough ground or something? Key goes to on position right?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Why even put the sender in the tank to test it? Hook it up to the sending unit wiring and operate the arm by hand. How are you even turning the tank upside down with the grounding wire attached? It's just a three inch wire running from the plug to the frame.
Also, are you sure the gauge is on the main tank - with the switch on the dash?
mini73
mini73
I tried that but it did not work. Also hard to see the gauge whir under the truck. I'll get the wife out here to look at the gauge. I got the switch pushed over to the left side which says main on it. Does the key have to be in the the run position or can it be in the ACC position? If the gauge does not work where should I start trouble shooting first? I know the IVR works as I got all the other gauges working now.
Viperwolf1
electron whisperer
Key can be in ON or ACC. Need a ground at the sender to work. I suggest checking for voltage at sender wire. No voltage means problem is further up towards switch or gauge. Switches have a tendancy to get dirty inside and not work well. You could try spraying it out with some contact cleaner or its pretty easy to just take it apart and clean it. If it has never worked the wiring might be monkeyed with at the back of the switch.
mini73
mini73
Took the grond wire going from the pigtail to the frame at the sending unit off and cleaned it up good so now that should be good. I took a test light and with the key o in either position I get a pulse on both terminals coming off the gauge. I tried to use the test light on the pigtail going to the sending unit but I get nothing. I am guessing I have a break in the orange wire somewhere between the gauge and the sending unit right? I followed it down from the gauge to the sending unit but really did not see anything thing that it be wrong. I appreciate all the help!
Viperwolf1
electron whisperer
Look at the switch. You can bypass it by connecting the 2 orange wires together.
mini73
mini73
Finally got the switch out of the dash. Boy, it a pain working under there! Took the 2 orange wires off the switch and connected them together and the gauge works now. Im guess the switch is bad?
Viperwolf1
electron whisperer
Probably just dirty. Take it apart by bending the tabs. Don't lose the balls or springs.
mini73
mini73
Ok. Will try tomorrow. Going to take a break from working on the bronco. Been trying to get he rest of the things together so I can put the rest of the brake and wheels back on and get it on the ground. Wondering if I should try and do my own brake lines with the different lengths already made up at napa or just wait and buy the brake line kit from TBP?
thegreatjustino
Stockton, CA
Phil told me the same thing a couple of years ago. I've disassembled and cleaned two of them, and they work perfectly now. I would have just replaced the switches if it hadn't been for the suggestion.
jhill52
Glad you found the fuel sender problem. Making your own brake lines is fairly easy. I make them all the time. You will need a bender and a flairing tool.
mini73
mini73
Got that stuff at work. Was thinking of buying the ones that have the flares already done and they come on different lengths. Just wondering what sizes I would need. Maybe ale the ones off( if I can) and get some rough measurements?
