stock rims
dougsride
are there any stock ford rims that will cross match to a bronco? Need ones that will also work with stock hub caps. Also will they work with gm disc conversion. I know where a 74 f100 is at and I might be able to get the rims off it.
1sicbronconut
Those 74' F100 wheels will work great.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've pulled stock Ford steel rims off of all kinds of 60s and 70s pickups at the local junk yard. Some are riveted together, some are welded, but size and fit wise, they are identical to EB rims.
Golfball
Not sure on the hubcap fitment but Ford truck wheels up to the mid (maybe late) 90 are the same bolt pattern and also Dodge pickup wheels are 5 x 5.5" bolt pattern as well.
