Can this direct fit Ididit Steering shaft work for other years than 76-77. I really wan to install a stock steering wheel on a tilt, column shift shaft. Has anybody tried this? If not why don't they make them for other years? They def should.
https://www.wildhorses4x4.com/produ...t_Fit_76-77_Steel_Column_Shift/Ididit_Columns
If that doesn't work is it possible to install a stock wheel on this shaft. Can a bracket or modification be made to make it work.
https://www.wildhorses4x4.com/product/Custom-Tilt-Column-Column-Shift/Bronco_Tilt_Columns
Need Help!!
Need Help!!
