Swerve
- Jul 31, 2014
- 526
Hello,
Can anyone with Dana 44 HP experience give me an idea of any clearance issues that I may run into? Stock width.
Did any of you get a pinion angle that worked well? If so, what degree? What size lift were you running? Which engine / transfer case combo? Did you achieve the good pinion angle with C bushings or were you able to set up the wedges and inner C's in good position? If so, any specs?
I am having Currie build a stock width HP front Dana 44 for my '76. I have a 5 1/2" Wild horses lift. 351W, Dana 20 transfer case.
Any real world advice from High Pinion front axle users is greatly appreciated!
Please, I am not looking for opinions for better front axle choices, I know there are others (Dana 60, Ford 9 / Dana 60 hybrid, etc...) please stick to Dana 44 HP front...
Thanks!
Swerve.
Thanks!
Swerve.
