Stock width Hi-pinion D60 with 3 1/2" lift? Will I have an oil pan left?? : )
nvrstuk
Looking at a hi-pinion D60 with a 3 1/2" lift...what kind of clearance issues? Can it be done without going full width? What distance would I cut the axle tube down on the drivers side btw the inner C and the "flange" on the center section to have enough clearance?
Got some feedback from a couple guys already...thanks
Apogee
Which D60...78-79 configuration or 1985-1991 if we're assuming the kingpin units, or are you looking at the 1992-1997 ball joint models as well?
