Stopping 37's
JohnJohn
Richmond
Guys,
I just finished a bunch of upgrades to my trail rig including a front disk conversion. I am running 37" tires on H1 double beadlocks (heavy wheels) with stock 10.5" rear drums and new 77 Bronco disk brakes up front with the 77 style proportioning valve and the vacuum power break booster. It looks like the PO installed a disk/drum master cylinder as well. I also replace all of the brake lines.
I want to replace the rear wheel cylinders just in case and bleed the system some more just in case but should I be able to lock the fronts up when I pound the brake?
At the moment when I put the peddle to the floor it stops but I don't/can't lock them up. I just wanted to know if I should be able to or if it could be a bit of air in my lines.
Thanks,
John
hyghlndr
Hockessin, Delaware
I can lock up mine, the other thing you will likely hear is to go ahead and do the hydroboost setup. I need to get mine converted. Out on the trail it should make the work of stopping a lot easier.
JohnJohn
JohnJohn
Richmond
thanks for the response. I will replace the rear cylinders and bleed the system again. the rear cylinders are the only thing I did not replace.
I did a hydro conversion on my 77 and will do it on this 70 over the summer but am just trying to get to the Roundup next week.
Yeller
Rogers County Oklahoma
Locking up 37's without hydro boost is asking a lot of the system, it was never designed for a tire/wheel of that mass. Not just the rotating mass but the 25% additional leverage on the brakes over a stock tire, there's also more traction from a larger foot print of the tire. That's part of the reason I always try to put 14" rotors on the front of new builds, its an automatic 23% gain in braking over a stock rotor but do require a 17" wheel.
JohnJohn
JohnJohn
Richmond
What parts would I use to fit 14" rotors?
Sent from my SM-G930V using Tapatalk
399strokerEB
Wasilla, AK
I had the same problem with mine, did the rear disk conversion and it pretty much cut my braking distance in half.
Wilwood offers a big brake option. At the moment that is the only way to get bigger rotors without going to 1-ton axles.
Yeller
I've been redrilling later model F150 rear rotors and making a custom bracket for the caliper. I've used both Wilwood and stock gm style calipers. However I've not done it on a D44, just D60 based stuff so I'm not real sure how it works out on a 44. I've also used Wilwood rotor hats and a custom water jet cut rotors.
muskrat
John, I'll make sure I'm wheeling behind you on the trails next week!!
