Straight 6 Bronco? Huh?
G
Guest
Guest
Okay, here goes. I'm looking at buying a mate's full-size '89 Bronco thinking I was going to get a V-8. Turns out it's got a straight six, which he insists is 'old skool'. As far as I knew Ford didn't go into 6-pot kettles. I thought it went, 4-pot kettle, V-4, V-6, V-8, V-10 big-rigs and V-12.<br><br>I know the Bronco II (Downsized) ran off a V-6 and the rule of thumb goes V-anything have more ponies-per-litre than their kettle-counterpart. So the way I see it a straight six isn't enough to pull a Bronco II far less a full-sized one.<br><br>I'm hoping that this Bronco is something I can take to a Ford dealership to have inspected and serviced before I go working on it and I'm not sure if Ford will inspect something that has a GMC or Dodge engine in it.<br><br>Your opinions please.<br><br>Are my fears unfounded, or is my mate full of shizzie?
bpassmore
Houston, TX
Hes probably right!<br>the 4.9L I6 is probably one of the most popular 6 cyl engines ford ever made. Very strong, very tough, and very common.<br><br>Apart from having to check and adjust the valve train fairly often, they rock. (If you dont have a 302/351)<br><br>good luck~
Rustytruck
The inline 6 is a good motor and produces alot of torque good for pulling or real get down grunt work. They are laking in freeway finness and high RPM sand running but are a great work horse. They last forever due to no cooling issues and extra main bearing support. This is a truck motor and acts as such. They were used in alot of fleet vechicles. Ill bet the truck is a stick? Check the body tag on the truck and the under hood sticker it will tell you if it is the right motor or not.
truemouse
Fear and Loathing in Lakewood (WA)
Okay, so what should the body tag and the hood sticker say? Is there any weird American code I should be aware of?<br><br>And yes it's a stick. I'm Euro-trash, so I'm used to stick shift. I mean I learned to drive in a Citroen 2cv, and that didn't even have a synchro in 1st.
6677ebman
I'm sure it's legit, I'd just as soon have a 300/6 w/ a 5 speed, they will run forever. This is no BS, I once saw one with 700,000 miles on it!! They have tons of torque, and willl get about 20 mpg. I know some people who quit buying Fords when they stopped producing the 4.9 (300 CID) in '94.
truemouse
Uhm, my old '96 Citroen AX had 640,000 miles on it when I left it behind in Germany (I commuted between Germany and Scotland many a time.) and that's after it had a slammed SUV (Hairdressers, why?) drive through the passenger door and when I flew off a 90 deg corner in the middle of the night, through a fence and up-rooting a tree stump, (was left there on top of the up-rooted stump, all four wheels off the grounds, and no discernable damage to my car) all on the original engine with no overhaul.
