Straight 6 fuel pump
Bdhand
Are all straight six 170 fuel pumps not the same. In this pic the one on the left is the one I took out of my bronco the one on the right is a Airtex 6399 but it does not look like it will work???!!!!
B RON CO
Statesville, NC
Hi, it is possible the new fuel pump on the right will work fine. BUT the old pump is not original. Your Bronco came with a fuel pump (Carter?) with an extra vacuum port for the windshield wipers. So I would install the new fuel pump after packing the lever arm pocket with white grease (old school) and greasing the lever. Then rotate the engine by hand from the harmonic balancer bolt to make sure there is no binding. Then you should be good to go. Good luck
Bdhand
Bdhand
Quick question. The one on the left installed with the arm pointing down. The new pump on the right will only install with the lever pointing up. Is this a problem? Does it matter if the arm is pointing up or down?
okie4570
NW OK
The arm has to be pointed down on every 170 fuel pump I've installed
hucklburry rev2
I got mine for my 66 170 at napa a few years ago, don't see it there now.
Rockauto, I looked at a 67 with 170, get this part # GMB 5258670 - it has the vacuum booster for the wipers, if you are still running vacuum wipers (I am).
Rock auto is out of stock
A google search for that part # has some ebay listings with no picture, so I don't trust those.
It also has:
scroll down to bottom of page: https://www.partsgeek.com/catalog/1967/ford/bronco/fuel_delivery/fuel_pump.html
Maybe more searching will show it locally for you, I didn't see it at napa anymore, which is getting normal, all the old stuff disappearing
B RON CO
Statesville, NC
Hi, okie4570 is right. That is why I said to turn the engine over by hand. I forgot why there are different pumps. Good luck
TNcowboy
It also has:
I just bought one from napa a few months ago and looks like they will ship one to you direct. Tom's also has them https://tomsoffroad.com/parts/66-69-ford-bronco-6-cylinder-mechanical-fuel-pump-with-vacuum
Bdhand
Bdhand
I’m not running vacuum wiper anymore got electric ones!
Bdhand
Bdhand
Here is the one I think I have from Auto zone but it says it doesn’t fit my vehicle 🤣🤣🤦🏼*♂️🤦🏼*♂️🤦🏼*♂️🤦🏼*♂️🤦🏼*♂️
Bdhand
Bdhand
Here is a fellow Facebook friend that has the same engine and looks like he is using one like the new one I have that the lever points up.
Bdhand
Bdhand
Went ahead and took a chance and put it in and it worked no problem. So now we know!!
jerry
Bakersfield, CA
As a side comment - and someone who knows better hopefully will comment - it appears based on its construction your old pump could be rebuilt with a kit.
