strange blinker issue
zbronco
Houston
When driving the bronco today the right blinker quite working. The left side works. I checked the bulbs, and they look fine, checked to see if I was getting power to the socket and I do not see anything. I heard the blinker relay in the cab blinking really fast so I know power is getting to the relay. The strange part is I hear a clicking from the coil and disti with the engine off and the right blinker on. I pulled the coil wire and see a spark jumping from the coil wire to the negative side of the coil.
When the engine is running and I turn on the right blinker it does not seem to affect the engine but still no blinker light.
Original wiring, no previous issues.
Any idea what to start with, bad relay? How and why does it affect the coil.
thanks
oleguy74
calif city ca
s does youremergency flashers work?and does brake lites work?if so bad turn sig sw.also what does your indicator lights do?short.
Z
zbronco
Houston
it is/was strange.. The flashers worked, brake lights worked, driving lights worked, just the right blinker did not work.
It is not a fuse..
But I did isolate the issue. one of the PO tapped into a few wires on the tail light harness I am guessing for a trailer lights. The wires were tucked on top of the gas tank and several were stripped back. I am guessing they were shorting..
not sure why a fuse would not have blown or why it shorted to the coil but once I cut the open wire leads everything was fine. One of the open wires was hot.
Viperwolf1
electron whisperer
The short at the rear wiring was putting a big load on the turn signal circuit. That's why the flasher was fast. That big load was also affecting the voltage at the ignition switch, where turn signal power comes from. When the turn signal flasher was open the voltage would be high and ignition coil would charge. When the flasher closed the voltage dropped because of the minimal resisitance in the turn circuit. That voltage drop caused the coil to discharge. Make sure you have the correct size fuse in the turn circuit.
Gweiner
Charlotte
I am having the same issue (no right turn blinker, but lights all work). Checked and cleaned all my grounds at each light and still nothing. What/ where r the fuses mentioned in the previous post. All the ones in the gove box look fine. Help!
Viperwolf1
electron whisperer
It's very unlikely you have the same problem. The fuses are in the stock fusebox. Fuse #2 is for the turn signals, but it would affect both right and left.
The problem can only be between the turn signal switch and the affected light. Since the left turn signal works, you know there is power to the turn signal circuit. Turn signal switches have high failure rates because they are mechanical. Rear wiring harnesses can have high failure rates if you have dual exhaust (wiring is too close to the heat). The turn signals, hazards and brake lights (on rear) all use the same wires between the turn switch and the lights. See which of those work and which do not. If none of those work the problem is either in the wire or at the bulb itself. A voltmeter can narrow that down even further.
Z
zbronco
Houston
I continued to chase electrical gremlims this weekend. When I started I had one blinker that would not work but the hazards worked all other lights worked. I found some shorted wires on the rear harness cleaned that up and the blinkers worked again. But the horn quit working. Started checking voltage and found very high voltage at the fuse block.. Check charging at the battery and it was high 17-18 V.. Changed the regulator, same issue, check the grounds again and they looked fine.
Went back to the horn and could see the horn wire was getting power when the horn was pushed and the horn work with a test wire. when the horn wire was connected I did not see any power but could hear a clicking. pulled the horn relay out and charging went back to 14.8-15V/
I took apart the relay and cleaned the contacts, put back in and the horn works and system is charging at 14.5 - 15 V.
not sure if the bad horn relay could cause a high voltage charge or is I have a bigger issue.
Viperwolf1
electron whisperer
Make sure the regulator has a good ground. It would be even better to ground it directly to the alternator. There is supposed to be a wire in the alt harness for this but they can be easily fried if the engine ground is bad and the starter is engaged. Also look at the orange wire going to the alt.
