Strange Cooling issue
Cali Orange
Sacramento, CA
I am having a problem with overheating at freeway speed and usually while climbing even te smallest of grades. My bronco has a '91 5.0EFI with all the latest in cooling equipment. Aluminum 3 core from WH, Derale 18" puller fan from WH, Flowcooler wp, Derale transmission cooler with electric fan mounted where heater air intake used to be, new 180 degree thermostat, Summit Racing fan thermostat 185on 170off. Problem is recent and I cannot figure it out, never had a problem before and haven't changed anything except adding the fan therostat and i was having the problem before that anyhow. I have read several cooling forums and the onnly thing I haven't tried is smaller wp pulley. However I just came back from the Jeepers Jamboree on the awesome Rubicon Trail and have no issues while crawling (210 max usually 195) but on the way home on the freeway it heated up to 240 climbing Donner Lake grade. Also have aftermarket Auto Meter water temp gauge. Also I am running a rebuilt C-4 with synthetic fluid. Any ideas out there?
00gyrhed
check your advance and the vacuum pots and make sure they are working. Sometimes too much advance will show as overheating in just this condition.
Cali Orange
Cali Orange
Sacramento, CA
I do not have an advance because of computer controlled EFI but i did set the timing at 10 degrees. The radiator is not shrouded but the 18" fan covers the majority of the radiator. This is the same set up that Jim the owner of Wild Horses runs on Nightmare. Aluminum Rad with 18" derale fan no shroud. He states he doesn't even run his fan on the freeway, one difference he has a manual trans.
John Marinan
Durango CO.
Air in the system? I've heard that a fan that moves too slowly can actually block airflow.
Wrong intake manifold gaskets? Some gaskets block off the rear water passage.
Probably none of these but with small block Fords you never know.
chase8266
vegas/slc/medford,OR
Ive seen a couple of these post with overheating at 65 to 75 and running cooler below that speed,my personal opinion the air is not circulating in the engine compartment,i think maybe a hood scoop or vented fender wells mite help.my 2cents
If you have holes in the back of the hood, try plugging them (blue painters tape is a good shot).
Another one that people often overlook, the fan. If you put the fan on backwards it will still move air in the correct direction, but not nearly as well.
The leading edge (the part by the radiator) should be parrellel to the radiator and perpenducler to the airflow.
The trailing edge (part by the motor) should curve and point more at the motor.
The idea is the curve of the blade scoopes the air and the arch of the blade pushes it back.
Backwards the leading edge will wipe the core of the radiator and the trailing edge will be a blocker.
So did you take the fan off and put it on backwards?
ransil
fan should NOT come into play while going over 20 mph the "ram air effect" should be cooling the motor.
Is the radiator sealed to the core support?
do you have a big winch blocking air flow?
mud & debris cooler clogging cooling fins.
jpopsbronco
Irvine, CA
Yeah I have heard the winch one a few times, What do you have in front of your grill? big winch on a big bumper? how long have you had the problem for? ie when did it start as far as you know- when you got a new motor? or new radiator?
Cali Orange
Cali Orange
Sacramento, CA
I have not made any changes recently. The fan, worked great for a year and half and then now I am having a problem so i am sure it is not running backwards, radiator is sealed to core support, overflow bottle is functioning, I do have a Warn M8000 winch on a Pre-runner bumper , but the M8000 is not very big and I have had it from day one, I do not have any scoop on the hood still running stock hood and I also have not cut out the fender skirts but i do have a 3" body lift which allows "some" air to circulate the engine compartment but I also have not had a problem with this before and i guess that is the hardest part because I have changed nothing since the problem started except I replced the Thermostat with a 180 instead of a 195 and it worked fine for a about a week or two (but I am not sure if i ran it on the freeway after that) and then right back to the same problem and remember it runs at 195 and perfect when i am crawling stuck in traffic etc. Afriend mentioned to me his bronco would overheat and he narrowed it down to his tranny get to hot from his 3rd gear band slipping and creating excess friction and heating up the trans and therefoer heating up his engine. Has anyone ever heard of anything like that? It partially makes sense for my situation because my overheating gets worse when i am under a load like hill climbing on the highway. Keep the ideas coming because i have none left!!! Thanks everyone.
broncnaz
You will always build more heat when climbing a hill. Unless you radiator has a internal tranny cooler which most aluminum jobs dont then the tranny is probably not the cause of your problem although then again 35in tires 4.10 gears may be putting a little extra strain on the tranny.
I dont think you need a smaller WP pulley with the flow cooler pump if anything you may already have to much waterflow through the system. Quite a few people have actually develped cooling issues when a flow cooler or similar WP was installed once they went back to the stock pump the problem went away.
The easiest and probably the first thing I might try is blocking the gap between the body and frame in the front as the extra air flowing under the body at that point could be causing the airflow under the hood to get backed up and up goes the temps.
Worst case that aluminum radiator has develped a lot of corrosion or electrolis inside and is not transfering heat like it did when it was new.
FASTERDAMITT
Oceanside
I had a highway heating issue, I was running reduced pulley's, Flowkooler pump, cowl hood and open inner fenders. Put stock pullys on and a slight change, replaced the Flowkooler with stock pump and the truck stays at 195 constant now.
BwoncoHowie
C-4 Wizard
When this problem happened to my 289 powered mustang,(it would overheat at 70 MPH and cool off to normal when I slowed down to 55) I found that over half of my radiator tubes were restricted or completely blocked with chunks of rust and scale. The coolant was fairly clean but the chunks dislodged from the water jackets inside the engine block during a long trip and got trapped in areas where they couldnt pass through.
Cali Orange
Cali Orange
Sacramento, CA
BwoncoHowie, what is the best way to check if i have any blockage in the radiator? I will also try a stock wp as Fasterdamitt suggested. The idea that chunks of scale and rust are clogging my radiator is possible because when i installed the 5.0 the previous owner had run straight tap water in the engine and there was a lot rust in it which I thought I had cleaned very well but maybe not as well as i thought or maybe more stuff has broken loose. Thanks for the help. I will post after I try these options.
00gyrhed
Sorry didn't really read the whole thing I guess. I posted from the hip.
First if you are not boiling water out of the radiator you are not overheating.
Check the temp gauge before you start fixing things. I had an auto meter gauge in a jeep that read 260 anytime the engine was warm. Pull the sensor out and put it in boiling water with the ignition on. See if it reads 212 (adjusted for your altitude). I bet it doesn't.
My bronco has a 71 302 with an 87 mustang EFI. It gets up to 230 under similar circumstnaces. I have a shrouded fan, fan clutch, brand new 4 row radiator. the radiator core is even a little larger than stock and there is no recirculation. I have been meaning to chck my gauge to see if 230 is really 230 but the truck doesn't boil out any water so I just don't worry about it. There isn't much I can do for it anyway. I blame it on the EFI computer leaning things out as far as possible while cruising looking for the best milage. What you have may be just fine. Check your gauge even though 240 sounds high if its off just 10 degrees its not such a big deal.
FASTERDAMITT
Oceanside
Also make sure your temp sensor is right behind the tstat somewhere so your reading coolant that is exiting the engine. I once had mine in the back of a Victor jr intake and thought I was overheating but turned out the rear coolant passage to the heads are blocked by the mold and the sensor recieved very little coolant flow. Always read 220-230 when I was actually at 195-210 with a 195 tstat.
