strange whining sound
RnrdTheFox
Superior, CO
On my way back from the exhaust shop, I can hear things that I couldn't with the open headers. Go figure ;D
When I'm in park gooseing it or accelerating from stand still through the gears, I hear a whine that sounds like it's coming from the tranny. It sounds like a P/S pump whine when it low. I've checked the tranny fluid and it right where it's supposed to be. What would this be? I'm hoping it's not the pump in the tranny.
I also hear a different whining coming from the rearend, but I think that is just because it needs to be shimmed for the correct drive angle. It's only there during acceleration and de-accleration. Coasting, it's not there. Thoughts?
thanks,
Renard
Apogee
Tangent, OR
Turn up the stereo ;)
At least it's not coming from the passenger seat, because those whines can be nearly impossible to fix. You didn't happen to install a gear-driven timing set or supercharger any time recently, did you?
It sounds like your tranny. You might just want to flush it and do a filter change for good measure. It'll give you a chance to check out anything in the pan and the condition of the fluid, unless it's all new. Do you know the history on the tranny? Have you checked the t-case...put it in 4WD, see if it sounds the same? I'm just throwing out ideas to see if anything sticks...I really don't have a clue. :D
RnrdTheFox
RnrdTheFox
Superior, CO
The tranny is supposed to have about 40K miles on it. I had taken apart to put the AA tailshaft in it for the Dana20. At that time, the guy said it looked good inside without much wear or signs of trouble. I haven't tried running it in 4WD just to check everything. Thanks.
FerrumCampitor
Hutchinson, MN
Probably coming from the t-case. Mine "developed" a whine recently when I had new, quieter exhaust put on it also. But I don't drive mine on the street so I just live with it until something breaks ;D
RnrdTheFox
RnrdTheFox
Superior, CO
If it were the T-Case it wouldn't do it in Park. Pretty sure it's coming from the tranny. Will probably take it to a tranny shop and get them to listen to it see what they think.
LOKMAN
MODESTO
are you sure that wasnt a ch**y driving by your eb..i hear alot of that ..just kidding check your fluid level on your transfer case thats what was wrong with mine.
Coasty
sandwich
Ring and pinion are not set correctly on the "drive" side, that's your noise in the rear end.
broncow72
Village Idiot
Spring,TX.
I actually read this statement.%) ;)
If only in Park I would suspect the pump. I am no trans expert by any means. I can only think of one thing, other than the motor of course, that turns while the trans is in park and that's the pump.
I'm not sure if any of the planetaries free wheel while in park. Would be cool if the auto trans gurus gave a quick rundown on the operation of a auto.
RnrdTheFox
RnrdTheFox
Superior, CO
Yeah, that's what I was thinking too. That just sucks if it is. I really don't want to have to drop the tranny. I was also wondering if my torque converter is pulled too far forward and that might be causing it. But, it didn't think it required shims are anything. Thanks.
BwoncoHowie
C-4 Wizard
A couple things can cause a pump whine in the C-4.
Worn out pump bushing and or converter hub.
pump gears worn where they join the converter hub
plugged or restricted filter.
RnrdTheFox
RnrdTheFox
Superior, CO
Thanks. I would assume the same apply for a 4R70W. It's supposed to have ~40k miles on it. But, you never know. I'm going to take it to a tranny shop and see what they saw mybe friday.
Canuck
Corunna Ontario
I have just had a buddy build my tranny(A awsome mechanic)
I also have a whine. He put in a shift kit also and alot of the guts from a C5 mustang. shifts great, but whines. Hope its not the pump
Gummi Bear
As soon as I read your post, this is what immediately popped into my brain...
http://youtube.com/watch?v=Jb01KFAZUO4
BwoncoHowie
C-4 Wizard
4R70W has Gerotor type gears that dont make the same noise as the C-4 gear.
broncow72
Village Idiot
Spring,TX.
All of a sudden I heard a similar whine while filling my work truck yesterday. But the truck wasn't even running. Then it dawned on me. It was everyone at the gas station.;D ;D
Rockrawl
San Antonio, TX
My t-case whines/rattles between coast and drive. If I put my hand on the shifter, I can feel that its coming from the t-case more than from the trans. My trans guy said this is probably because the bearings on the middle shaft in my D20 are getting worn out. Sounds like maybe you're having the same prob.
